Extractor Suite: More granular offset for delta loads (15.01.2021)
The delta load offset lets you run delta loads based on the newest date in the existing data minus the offset. Currently, the delta load offset is defined in days by default and cannot be changed.
However, this new feature lets you define the offset parameter as various new time units such as hours, days and minutes.
Adjusting the time unit allows you to run more granular delta loads improving extraction performance and operational use cases. (Days are still selected as the default unit. So no further action is required if you are already using offset for delta loads and plan to continue with days).
