Formulate Your Problem as an ML Problem
This section is a guide to the suggested approach for framing an ML problem:
Articulate your problem.
Start simple.
Identify Your Data Sources.
Design your data for the model.
Determine where data comes from.
Determine easily obtained inputs.
Ability to Learn.
Think About Potential Bias.
Content
Articulate Your Problem
There are several subtypes of classification and regression. Use the corresponding flowchart to identify which subtype you are using. This flowchart helps you assemble the right language to discuss your problem with other ML practitioners. Use the Classification or Regression flowchart depending on your business problem.
Our problem is best framed as:
Binary classification
Unidimensional regression
Multi-class single-label classification
Multi-class multi-label classification
Multidimensional regression
Clustering (unsupervised)
Other (translation, parsing, bounding box id, etc.)
Then, after framing the problem, explain what the model will predict.
Putting each of these elements together results in a succinct problem statement, such as the following:
Example |
Our problem is best framed as 3-class, single-label classification, which predicts whether a video will be in one of three classes— |
Start Simple
Can you simplify your problem?
First, simplify your modeling task. State your given problem as a binary classification or a unidimensional regression problem (or both). Both problems are well-traversed, supervised approaches that have plenty of tooling and expert support to help get you started.
Then, for that task, use the simplest model possible. A simple model is easier to implement and understand. Once you have a full ML pipeline, you can iterate on the simple model with greater ease.
Examples |
We will predict whether an uploaded video is likely to become popular or not (binary classification). |
We will predict an uploaded video’s popularity in terms of the number of views it will receive within a 28 day window (regression). |
Simple models provide a good baseline, even if you don't end up launching them. In fact, a simple model is probably better than you think. Starting simple can help you determine whether a complex model is even justified. More complex models are harder and slower to train and more difficult to understand, so stay simple unless the complexity provides a large enough improvement in model quality to justify these tradeoffs.
Note: Usually, most of ML is on the data side. Celonis simplifies the data pipeline with the Data Integration, model deployments using schedules and the Action Engine.
The biggest gain from ML tends to be the first launch, since that's when you can first leverage your data. Further tuning still gives wins, but, generally, the biggest gain is at the start so it's good to pick well-tested methods to make the process easier.
Provide answers to the following questions about your labels:
How much labeled data do you have?
What is the source of your label?
Is your label closely connected to the decision you will be making?
Example |
Our data set consists of 100,000 examples about past uploaded videos with popularity data and video descriptions. |
Design your Data for the Model
Identify the data that your ML system should use to make predictions (input -> output), as in the following table:
Title | Channel | Upload Time | Uploader's Recent Videos | Output (label) |
My silly cat | Alice | 2018-03-21 08:00 | Another cat video, yet another cat | Very popular |
A snake video | Bob | 2018-04-03 12:00 | None | Not popular |
Each row constitutes one piece of data for which one prediction is made. Only include information that is available at the moment the prediction is made. Each input can be a scalar or a 1-dimensional (1D) list of integers, floats, or bytes (including strings).
If an input is not a scalar or 1D list, consider whether that is the best representation for your data. For example:
If a cell represents two or more semantically different things in a 1D list, you may wish to split these into separate inputs.
If a cell represents a nested protocol buffer, you may wish to flatten out each field of the nested protocol buffer.
Exceptions: audio, image and video data, where a cell is a blob of bytes.
Tips for audio/image/video data | Examples |
There may not be explicit inputs. | The only inputs may be the bytes for the audio/image/video. |
There may be metadata accompanying the image. | Compression format, object bounding boxes, source |
Your outputs may be simplified for an initial implementation. | Rather than doing bounding-box object detection, you may create a simple binary classifier that learns whether one type of object is present in the image or not. |
Determine Where Data Comes From
Assess how much work it will be to develop a data pipeline to construct each column for a row. When does the example output become available for training purposes? If the example output is difficult to obtain, you might want to revisit your output, and examine whether you can use a different output for your model.
Make sure all your inputs are available at prediction time in exactly the format you've written down. If it will be difficult to obtain certain feature values at prediction time, omit those features from your model.
Example |
We applied the labels |
Determine Easily Obtained Inputs
Pick 1-3 inputs that are easy to obtain and that you believe would produce a reasonable, initial outcome.
Which inputs would be useful for implementing heuristics mentioned previously?
Consider the engineering cost to develop a data pipeline to prepare the inputs, and the expected benefit of having each input in the model. Focus on inputs that can be obtained from a single system with a simple pipeline. Start with the minimum possible infrastructure.
Ability to Learn
Will the ML model be able to learn? List aspects of your problem that might cause difficulty learning. For example:
The data set doesn't contain enough positive labels.
The training data doesn't contain enough examples.
The labels are too noisy.
The system memorizes the training data, but has difficulty generalizing to new cases.
Example |
The measure "popular" is subjective based on the audience and inconsistent across video genres. Tastes change over time, so today's "popular" video might be tomorrow's "not popular" video. |
Many dataset are biased in some way. These biases may adversely affect training and the predictions made. For example:
A biased data source may not translate across multiple contexts.
The training sets may not be representative of the ultimate users of the models and may therefore provide them with a negative experience.
Example |
Since the measure "popular" is subjective, it is possible that the model will serve popular videos that reinforce unfair or biased societal views. |
Portions of this page are modifications based on work created and shared by Google and used according to terms described in the Creative Commons Attribution 4.0 License.
