Celonis Product Documentation
Migrate Data Model objects from Celonis 4 to EMS using Celonis Content-CLI
With this functionality you can migrate Data Model objects from Celonis 4 to the Data Integration in the EMS, leveraging the standard Transport (CTP) file format and the Content-CLI push command.
Migration overview
Migrating the Data Models
Post-migration steps
Migration overview
Data Model migration
  1. Set up the Content-CLI and create a profile
  2. Create a Transport file that includes the Data Model(s) to be migrated
  3. Use the Content-CLI push command to create the Data Pool(s) with the Data Model(s) in the Data Integration
  1. Set up the Data Sources, Extractions & Transformations
  2. Connect the Data Model tables to the respective Data Scope / Schema
Disclaimer
Please note that this migration is only supported with an on-premise version of 4.6 and above. If you need help at any point reach out to your CSM.
  1. Make yourself familiar with the Celonis Content- CLI and first create a profile which you will use for pushing the CTP-files.
  2. Create a Celonis 4 Transport (CTP file):
    • Log into the desired Celonis 4 instance
    • Navigate to the Transport creation screen
    • Add all Data Models you want to migrate to the Transport
    • Make sure to remember the specified password
    • The Global Content Administrator role of Celonis 4 is required to create Transport files
    • When creating the CTP file, make sure to only include the Data Models.
  3. Use the Content-CLI push command to create the Data Pool(s) with the Data Model(s) in the Data Integration:
    1. Upload the transport file to the Machine Learning Workbench (not required for local Content-CLI installations).
    2. Execute the push command for ctp files. The following syntax has to be used:
      content-cli push ctp -p <profile> -d -f <file> --password <password>
      To get more information, use the following command:
      content-cli push ctp --help
      Command to push a .ctp (Celonis 4 transport file) to create a package
      Options:
        -p, --profile <profile>            Profile which you want to use to push the analysis
        -a, --pushAnalysis                 Specify this option if you want to push analysis from the CTP file
        -d, --pushDataModels               Specify this option if you want to push data models from the CTP file
        --globalPoolName <globalPoolName>  Specify this option if you want to push all Data models into one newly created pool along with value to set the name of the pool to be created (default: null)
        --existingPoolId <existingPoolId>  Specify this option if you want to push all Data models into one already existing pool with provided ID (default: null)
        -s, --spaceKey <spaceKey>          The key of the destination space where the analyses from .ctp file will be created. (default: "")
        -f, --file <file>                  The .ctp file you want to push
        --password <password>              The password used for extracting the .ctp file
        -h, --help                         display help for command
    • Either the Admin or the Analyst role are required to run the command successfully. Users with the Member role require additional permissions to the Data Integration & Machine Learning Workbench.
    • Make sure to use the ctp and the -d option if you want to push Data Models.
    • By default, the tool will create one new Data Pool per Data Model in the Transport. Instead, you could also:
      • Create one shared Data Pool for all Data Models by using --globalPoolName <globalPoolName>
      • Push all Data Models to an existing Data Pool by using--existingPoolId <existingPoolId>
    • It is possible to migrate Analyses and Data Models at the same time by using-da. Keep in mind that the Analyses will not yet be connected to the migrated Data Models in this case.
    Example:
    content-cli push ctp -p cpm2ems -d --existingPoolId somePool -f CE_TRANSPORT_CPM2EMS___P2P.CTP --password somePassword
  4. After sending a successful push request, the Data Model objects are automatically migrated into the respective Data Pool(s) into theGlobal Scope. The migration currently includes:
    • The tables of the Data Model
    • The foreign key relationships of the Data Model
    • The "General Mapping" from manually uploaded name
  1. Set up the Data Sources, Extractions &amp; Transformations.
    In case the standard push or the --globalPoolName option were used, the Data Pools are empty apart from the Data Model object itself.
    Therefore, the next steps are:
    • Establishing connection to the source system(s)
    • Setting up the Extraction Jobs
    • Creating the Transformation Jobs
    The final step that is required is to map the Data Model tables to the Vertica tables of the respective Data Scope / Schema.
    1. Go to the Edit screen of every Data Model table.
    2. Select the SchemaTable Name
Once all tables are mapped to respective Vertica tables, the Data Model can be loaded
