15. get_orchestration_engine_process_contexts — OE Get Process Contexts
Mode: Both · Category: Other
Lists or queries digital process instances from Orchestration Engine.
- id: get_orchestration_engine_process_contexts
- id: get_orchestration_engine_process_contexts unique_id: approval_contexts description: Lists approval process instances. digital_process_key: com.celonis.invoice.approval
Field | Type | Description |
| string | Pre-set digital process key filter. |
| string | Pre-set instance ID filter. |
