Running transformations
After publishing custom transformations to the OCPM Data Pool, you need to run the transformations to create objects and events from your custom object types and custom event types. These transformations will also need to be run to update any existing objects and events to which you’ve added new attributes or relationships.
Celonis stores custom transformations in the test:ocpm-data-job data job when you publish to the development environment, and in ocpm-data-job when you publish to the production environment. These data jobs are in the global scope for the OCPM Data Pool. These jobs contain both the Celonis-supplied transformations and your custom transformations. Celonis will optimize simple transformation scripts that don't include a join or WHERE clause to views. These views are already executed when published, and the executed SQL will be presented as a comment in the generated transformations for your information. You can use the instructions below to run or re-run the supplied transformations if they have not been run already.
If you have any problems, check Transformations for potential solutions.
  1. In the Celonis Platform, select Data > Objects and Events.
  2. Select Dashboard in the Objects and Events navigation panel to go to the dashboard.
  3. Select OCPM Data Pool to go to the data pool. You can also select Data > Data Integration from the navigation bar and select the "OCPM Data Pool" from the list of data pools.
  4. In the OCPM Data Pool, click the Data Jobs area.
  5. Select test:ocpm-data-job to create objects and events in the development environment or select ocpm-data-job to create objects and events in the production environment.
  6. In the list of transformations, select the name of any transformation to review its details. Transformations that haven't been validated or have failed validation are disabled automatically and won't be run as part of your data jobs. Go to the Transformations page in the Objects and Events UI to see which transformations have passed validation, failed validation, or not been validated yet.
  7. When you’re ready to run your transformations, click Execute Data Job. In the confirmation window, you can select a subset of the transformations.
    If there's a Celonis object type or event type that you don’t need, don’t have data for, or are building with data from a set of transformations for another source system, you can disable the transformations for this object type in the Objects and Events environment. If you disable a transformation that was previously run, the data for that object type or event type is removed from the table when you run the data job.
  8. Click Execute Selection to run the selected transformations.
    Any simple transformation scripts that don't include a join or WHERE clause, aren't new scripts, or haven't changed since the previous run will not be included in the transformation and will be replaced with a view.
  9. In the Data Jobs area in the OCPM Data Pool, the data job displays the status and execution time so far, and there’s a button if you want to stop the job running.
  10. You can monitor the status of the running transformations in the Logs tab for the data job. When the transformations have finished running, the status should show as "Successful". You can also see the status of the last run for each individual transformation in the Transformations page in the Objects and Events UI, and get a link to the logs to check on any errors.
  11. When you're ready to run your data jobs regularly, set up schedules for them. Scheduling data jobs for object-centric process mining tells you how.
The transformations populate the tables in the Celonis database in the OCPM Data Pool with your business data to create objects and events. When you run test:ocpm-data-job, you’ll get a test copy in tables with the prefix "t". When you run ocpm-data-job, you’ll get the objects and events in your production environment.
To view your objects and events and analyze your business processes with them, see Using objects and events for process mining. To use custom object types and custom event types, you’ll need to create custom perspectives following the instructions in Creating custom perspectives and event logs.
