Installing Celonis Platform Connector for Power BI
The steps you will follow are:
  1. In Celonis Platform: Define knowledge model
    Defining the data (records, KPIs, and so on)
  2. In Celonis Platform: Create application key
    Connecting to the instance
  3. In Celonis Platform: Grant permissions
    Granting the correct permission levels
  4. In Power BI: Connect to Celonis Platform
    Establishing connection
  5. In Power BI: Import Knowledge model records
The first step isn't necessary if you already have a published knowledge model.
