Configuring a connection between Orchestration Engine and Action Flow
Action Flow modules are components that are used for creating scenarios in Celonis.
To learn more about the way they work, see Types of Modules.
To establish a connection between the Orchestration Engine and Action Flows, you need to create a connection manually.
To configure the connection manually:
  1. Create an OAuth Client application with authentication methods. See Registering your OAuth client in Celonis Platform.
  2. Add permissions for the respective OAuth Client applications to the desired Celonis package. See Managing packages and package permissions.
  3. Add an Orchestration module in Action Flows, for example a Completion Event. An Orchestration window pops up, where you can check all the module’s details, and enter the required data.
  4. To open the connection configuration, choose ADD in the connections section. You'll see the Create a connection window.
  5. Enter the Client ID and the related Client Secret.
    • You can copy and paste the ID and the secret from previous step.
  6. Choose the environment with which you want to establish the connection.
  7. Choose SAVE to create the connection.
