Required directories and registry keys for Task Mining
The Task Mining Client software on a user's machine needs access to these directories and registry keys to work as expected. For the full system requirements for the Task Mining Client Software, see Task Mining Desktop Application.
In a virtual desktop infrastructure (VDI) environment, these directories and registry keys must be persisted between sessions. For the VDI options and limitations for Task Mining, see Virtual desktop infrastructure options for Task Mining.
Directory
Access type
%ProgramFiles(x86)%\Celonis SE\Celonis Task Mining
  • Read access during runtime.
  • Write access during installation.
Installation directory when installed for all users of a machine.
%LOCALAPPDATA%\Celonis SE\Celonis Task Mining
Installation directory when installed for the current user only.
%USERPROFILE%\CelonisTaskMining
Read/write access during runtime.
Contains cached parquet and image files. Can be configured in the project configuration.
%LOCALAPPDATA%\Celonis\TaskMiningClient
Contains cached configuration, application settings and logs.
%LOCALAPPDATA%\Local\Celonis\TaskMiningClient\logs
  • Write access during runtime.
Logging folder for the Task Mining Client. Contains the current log file TaskMiningClientLogs.txt and compressed archived log files (see Logging for the Task Mining Client software).
%LOCALAPPDATA%\Celonis_SE\CelonisTaskMining.Client._Url_< 32 alphanumeric characters><version of the client>
Contains required application settings.
We recommend making the entire %LOCALAPPDATA%\Celonis_SE directory persistent to ensure files are still available when the Task Mining Client software is updated.
<Personal Special Folder>
For further information, see Environment.SpecialFolder Enum.
Contains crash report files.
<Personal Special Folder>/Celonis Task Mining
Contains error log files if configuration could not be loaded.
Required registry keys
  • For HKMU, when the client is installed for all users of the machine (admin), the key will be under HKLM. When installed for the current user only, the key will be under HKCU.
  • For <SOFTWARE>: On 32-bit Windows systems, replace with Software. On 64-bit Windows systems, replace with Software\Wow6432Node.
If the registry key for autostart is not writable, the application will not autostart at system start.
Registry key
Access type
HKCU\<Software>\Celonis\TaskMining\installed
Registers installation of the application.
HKLM\<Software>\Celonis\TaskMining\activation_link_url
Activation link to automatically activate the client on the first start.
HKLM\<Software>\Celonis\TaskMining\client_certificate_subject
Client certificate subject used for secure gateway authentication.
HKLM\<Software>\Celonis\TaskMining\client_working_directory
Working directory of the Task Mining client.
HKLM\<Software>\Celonis\TaskMining\connection_timeout
Custom connection timeout.
HKLM\<Software>\Celonis\TaskMining\custom_extension_ids
Custom browser extension IDs for self-hosted rollouts.
HKLM\<Software>\Celonis\TaskMining\secure_gateway_server
Host URLs of the secure gateway server.
HKLM\<Software>\Celonis\TaskMining\service_principal_name
Service principal names used for the on-premise Task Mining gateway.
HKMU\<Software>\Celonis\TaskMining\extension_socket_port
Custom port for the Chrome Extension.
HKMU\<Software>\Google\Chrome\Extensions\ndfcgjlpabkombgfpckhglibdhnipbfl\update_url
Update URL of the Chrome Extension.
HKMU\<Software>\Microsoft\Edge\Extensions\ndfcgjlpabkombgfpckhglibdhnipbfl\update_url
Update URL of the Edge Extension.
HKMU\<Software>\Microsoft\Windows\CurrentVersion\Run\CelonisTaskMining
Autostart entry for the Task Mining client.
HKMU\<Software>\Classes\CelonisTaskMining\(Default)
Registers the Task Mining-specific URL.
HKMU\<Software>\Classes\CelonisTaskMining\shell\open\command\(Default)
Registers the shell command to open the client from URL.
HKMU\<Software>\Classes\CelonisTaskMining\URL Protocol
Enables browsers to open the Task Mining client from URL.
