Sending Data from Orchestration Engine to Celonis data model
Orchestration Engine's Process Orchestrations together with Action Flows allow for seamless interaction with Celonis knowledge models. You can use the data and signals received from Celonis as events in your business Process Orchestrations. When the processes finish, you can send back a response to Celonis using action feedback.
You can reuse data from Process Intelligence Graph in your Process Orchestration with the help of dedicated Action Flow module. See Write back to Data Pool table module Action Flow.
