SAML settings in Celonis Process Management Web
To install SAML authentication in Celonis Process Management Web please do as follows.
To configure an
Identity Providerplease navigate to the respective storage (system administration, storage collection or Storage), open the system settings and select the option "SAML settings". An Identity Provider which is configured here is valid for all underlying storages – so in the case of the system administration it is valid for the complete application and in the case of the a storage collection it is valid for all storage contained in that collection. For theIdentity Providerthe settings have to be adjusted here.Figure 27. Identity Provider
We need the following information from the
Identity ProviderMetadata XML fileof the Identity Provider (from the AD FS): You can download it from your AD FS-Server with, for example, https://fs.example.com/FederationMetadata/2007-06/FederationMetadata.xmlEntity ID(also in the meta data), i.e. http://fs.example.com/adfs/services/trustSSO Service URL(also in the meta data), https://fs.example.com/adfs/ls Please note that the https log is entered here.
Enter the Entity ID and SSO Service URL in the respective entry fields and upload the meta data XML.
1)For authentication in Celonis Process Management Web via SAML it is recommended to use the HTTPS binding. For an administrative access for Ploetz + Zeller it is necessary to set up another HTTPS binding for Port 4430. The following bindings should be configured in the IIS:
Figure 28. Bindings
Web.config – base configuration: Only Celonis Process Management Web 5.2/5.3/5.4: In the file Web.config, which can be found in the Celonis Process Management Web master folder, the following setting for SAML has to be activated because it is commented out by default:
\<add key="SymbioAuthenticationMode" value="SAML" /\>
Only Celonis Process Management Web 5.5-1807: For an administrative access for Ploetz + Zeller via port 4430 the PZAdminLogin setting in the file Web.config, which can be found in the Celonis Process Management Web master folder, needs to be set from „false" to „true":
\<add key="SAML.PZAdminLogin" value="true" /\>
Furthermore, it can be defined in the Web.config which user group from the Active Directory should have Administrator rights in Celonis Process Management Web (by default):
\<add key="Automation.AdminUsers" value="SymbioCloudAdmins" /\>
Now the administrative access via https://sample.symbioweb.com/_sysadmin/_admin should be possible. If not, please check: Adjust firewall settings and create rule for 80, 443, 4430. If, after the first login, the browser does not relay to Celonis Process Management Web automatically, please call up the page (https://sample.symbioweb.com/_sysadmin/_admin) again.
When the respective settings have been adjusted on the side of the
Identity Provider, the website is available via the HTTPS-Standard-Binding of Celonis Process Management Web via this Identity Provider.Login with a user who is a member of the administrator group
Celonis Process Management CloudAdminsor alternatively with a user from the administrator group configured in step 4.If you have already created other Celonis Process Management groups in your Active Directory those will be created and synchronized with the first login.
When an Active Directory user first logs onto Celonis Process Management Web he will be added with the role „Viewer" if he is not a member of the administrator group (i.e. Celonis Process Management CloudAdmins). If a user needs more rights, the Celonis Process Management Administrator has to add the respective user role for this user, for example, the role „Author" for Editor rights.
Notes
Authorization: The user roles of a user have to be managed by a Celonis Process Management administrator, i.e. members of a certain group do not automatically have the user role „Architect" if the user is a member of „Celonis Process Management Architects". Only members of the Celonis Process Management administrator group (i.e. Celonis Process Management CloudAdmins) have the user role "Administrator" automatically.
User groups: If AD groups are not created in Celonis Process Management when a user logs in or logs out despite a configured claim rule, it is most likely because the AD group in the Active Directory is not configured to “Global" or”Universal". See also MS Articles.
Figure 29. User Groups
If a user is part of many user groups (< 50) this could negatively influence the performance. This will be improved in the next version.
Login: If you notice a severe deterioration of performance the first time after the change to SAML (e.g. < 20 Sek.) it could be that (for example caused by a virus scanner) clearing the certificate might take longer on your web server. You can check that by activating CAPI2-Logging.
