Data flow between Orchestration Engine and Celonis Platform
Orchestration Engine's digital processes together with Make scenarios allow for seamless interaction with Celonis' knowledge models and Intelligence API. You can use the data and signals received from Celonis as triggers for your business digital processes. Then, when the processes finish, you can send back a response to Celonis using action feedback.
To Retrieving data from EMS from Celonis Platform in your digital process, you can use Make scenarios as triggers.
When your digital process is completed, you can Sending Data from Orchestration Engine to Celonis Platform to Celonis Platform.
