FAQs: General
How do I create an analysis from scratch?
You need analyst rights to use components or fullscreen components
You need a working Process Data Model.
Go to workspace overview in order and use Create Analysis in the Workspace analysis. Alternatively, you can use the Celonis Marketplace to include ready-to-use analyses for common processes and improvement areas.
How can I make the most of Tags?
Tags help you to classify Tiles, for example, by:
Process : Purchase to Pay, Accounts Receivable, Production...
Source system : SAP ECC, Salesforce...
Organization Part: Team A, Team B...
If you click the tag, you will only see the Tile with this tag; this helps you easily find the Tile you are looking for.
How do I delete a tag?
Remove the tag from the tiles where it is used.
Analysis ID and changes when moving or duplicating analyzes
Very large integers (>2^53) are not supported in Process Analytics. Use the ??? function in the integer data.
